Relationship class is read only
3551
10
08-01-2022 05:40 AM
MartinBertrand
I created a relationship class that is attributed and I can't edit it via Argis Desktop nor via sdk?
Aashis
by Esri Contributor
Currently, there is no way to update the relationship class via the Pro SDK.
You should use Geo Processing tools to update relationship class'  relationship rules,  split policy, migration , etc.
I am curious to know what you are editing.
PierreMasson
I've created 2 simple stand alone tables. Clients & Orders.
Clients: ObjectId, Name, FirstName, Email
Orders: ObjectId, ClientId, OrderDate
Then I created an attributed Relationship Class between the 2. Like many client can have many orders.And added a IsShipped (short) field to it.
I add a client manually, then I do the same for the Orders table where I set the apporiate ClientId.
Now I want to manually add an entry in the relationship class, but it's read-only.
I don't understand why. We were doing this easily a few months ago and it was working great. Of course we were doing it programatically in a more complexe data model than that but we hit that problem and we are trying to isolate the problem. This is the smaller we came up with. Why can't we add relationship data? Why is it read only??
Please help
Aashis
by Esri Contributor
What is the version of Pro and the geodatabase type, to see if we can reproduce the issue for investigation?
PierreMasson
ArcGIS Pro 2.9.2
Enterprise GeoDatabase on MS SQL.
Aashis
by Esri Contributor
Moved to the Pro forum, not related to the  Pro SDK.
Tags (1)
BarryNorthey
You had to be using a Standard or Advanced license to create the relationship class but a reminder for those who might not know that relationship classes are read-only and cannot be edited when using a Basic license. While citing the version of AGP is important, the license level can sometimes be more important.
PierreMasson
Using Standard
PierreMasson
Just run this script (replace the 3rd line by your database sde file. Then add data in both tables and try to add a record in  rel_Cars_CarColors. It's read only..
import arcpy
import sys
gdb = 'YOUR SDE PATH FILE HERE'
arcpy.env.workspace = gdb
resObj = arcpy.CreateTable_management(gdb, 'Cars')
tbl = resObj.getOutput(0)
arcpy.AddField_management('Cars', 'Make', 'TEXT', field_length=250, field_alias='Make', field_is_nullable='NON_NULLABLE', field_is_required='REQUIRED')
arcpy.AddField_management('Cars', 'Model', 'TEXT', field_length=250, field_alias='Model', field_is_nullable='NON_NULLABLE', field_is_required='REQUIRED')
arcpy.AddField_management('Cars', 'Year', 'LONG', field_alias='Year', field_is_nullable='NON_NULLABLE', field_is_required='REQUIRED')
resObj = arcpy.CreateTable_management(gdb, 'CarColors')
arcpy.AddField_management('CarColors', 'ColorName', 'TEXT', field_length=250, field_alias='Color Name', field_is_nullable='NON_NULLABLE', field_is_required='REQUIRED')
arcpy.AddField_management('CarColors', 'ColorCodesRGB', 'TEXT', field_length=6, field_alias='RGB', field_is_nullable='NON_NULLABLE', field_is_required='REQUIRED')
arcpy.CreateRelationshipClass_management(origin_table='Cars', destination_table='CarColors',
                                                     out_relationship_class='rel_Cars_CarColors',
                                                     relationship_type='SIMPLE', forward_label='AvailableColors', backward_label='Cars',
                                                     message_direction='Both', cardinality='MANY_TO_MANY', attributed='ATTRIBUTED',
                                                     origin_primary_key='OBJECTID', origin_foreign_key='CarId',
                                                     destination_primary_key='OBJECTID', destination_foreign_key='CarColorId')
tbl = 'rel_Cars_CarColors'
arcpy.AddField_management('rel_Cars_CarColors', 'Status', 'SHORT', field_is_nullable='NON_NULLABLE', field_is_required='REQUIRED')
PierreMasson
Nobody as a solution? I think it's a bug
