Reconstruct shape via ArcPy: How to validate geometry?
2133
02-16-2022 08:15 AM
Bud
Legendary Contributor
I have a field calculator Python script that I use to update the shape field of a FC.
 - Densifies any true curves.
 - Populates M-values of coordinates.
 - Reconstructs shape.
Expression:
new_shape( !SHAPE! )
Code Block:
def new_shape(geom):
    spatial_reference = geom.spatialReference
    geom = geom.densify("ANGLE", 10000, 0.174533)
    parts = arcpy.Array()
    for i in range(geom.partCount):
        part = geom.getPart(i)
        points = arcpy.Array()
        for j in range(part.count):
            point = part.getObject(j)
            point.M = geom.measureOnLine(point)
            points.append(point)
        parts.append(points)
    return arcpy.Polyline(parts, spatial_reference)
Screenshot
Question:
I want to add logic to the script that will check the new geometry for issues. I know from experience that problems in the code can mean that an empty geometry gets returned to the feature (not what I want).
 - I believe an empty geometry is a valid geometry. That's why the code doesn't error-out.
What kinds of things should I check for in the new geometry?
Ideas:
1. New shape isn't empty.
2. New point count vs. old point count.
3. New length vs. old length.
4. New part count vs. old part count.
5. Other?
if new_geom   and   new_geom.pointCount>=orig_geom.pointCount   and   abs(orig_geom.length-new_geom.length) < 1   and   new_geom.partCount==orig_geom.partCount:
    return new_geom
else:
    return orig_geom
Or is it unnecessary to check those things, other than checking for an empty shape, since ArcPy validates the geometry for us?
I'm using ArcMap 10.7.1. But I believe this would apply to ArcGIS Pro too. (Oracle 18c SDE.ST_GEOMETRY)
DanPatterson
MVP Esteemed Contributor
5.  Other
Have you looked at what other things check for
Invalid Geometry—ArcGIS Pro | Documentation
there are a whole slew of other links in the table of contents by that link that are geometry specific
plus the various things esri checks for
Check Geometry (Data Management)—ArcGIS Pro | Documentation
there is an  Open Geospatial Consortium (OGC) validation method  link which opens a document to their standards
... sort of retired...
