Rearrange string with Attribute rule
5343
8
11-06-2020 01:09 AM
KARIMLABIDI
Hello,
I'm a newbie on Arcade, i very like this language but it's new for me and I have some difficulties to find my happiness!
I would like to rearrange a string Address in a field, I would like put the last word in 1st place and the other after (in parenthesis)
For example: RUE GEORGES BONNAC will be BONNAC (RUE GEORGES).
I Think, I have to split my string et count the words but i got a dictionary error and I don't what to do.
Thank you everybody.
2 Solutions
XanderBakker
Esri Esteemed Contributor
Hi KARIM LABIDI ,
I think this could do the trick:
var township = FeatureSetByName($datastore, "GDB.SIGWRITER.FV_TRONC_L", ["NOM_VOIE"], True);
var intersectLayer = Intersects(township, $feature);
var cnt = Count(intersectLayer);
if (cnt > 0) {
    var feat = First(intersectLayer);
    var nomvoie = feat["NOM_VOIE"];
    if (IsEmpty(nomvoie)) {
        return "no NOM VOIE"; // or perhaps return null
    } else {
        var words = Split(nomvoie, " ");
        var cnt2 = Count(words);
        var lastword = words[cnt2-1];
        if (cnt2 > 1) {
            var otherwords = [];
            for (var i = 0; i < cnt2-1; i++) {
                otherwords[Count(otherwords)] = words[i];
            return lastword + " (" +  Concatenate(otherwords, " ") + ")";
        } else {
            return lastword;
} else {
    return "No township found"; // or perhaps return null
I tested with this code:
// RUE GEORGES BONNAC would be BONNAC (RUE GEORGES)
var nomvoie = "RUE GEORGES BONNAC";
} else {
    Console(words);
    if (cnt2 > 1) {
    } else {
        return lastword;
... which returned this:
XanderBakker
Hi kbm_admin ,
Sure. Can you try this?
if (cnt > 0) {
    } else {
        Console(words);
        var add = "";
        Console(Find("'", lastword));
        if (Find("'", lastword) > -1) {
            var arr = Split(lastword, "'");
            add = " " + arr[0] + "'";
            lastword = arr[1];
        if (cnt2 > 1) {
            return lastword + " (" +  Concatenate(otherwords, " ") + add + ")";
        } else {
            return lastword;
} else {
XanderBakker
Hi kbm_admin ,
There are a couple of things that may be going wrong here:
  • In you code example you don't return anything
  • The error might be related to how you read the field value from the feature. When retrieving a value from a field that contains an underscore always use feature["Field_Name"] instead of feature.Field_Name
  • Also it might be possible that no features where found with the intersect and when you try to take the first feature from a collection that has no feature it might fail. So always do a count to see if you have anything and continue accordingly
Try this:
if (cnt > 0) {
    } else {
        // define what to return, let's say you want to first word
        return words[0];
} else {
KARIMLABIDI
HI Xander, thanks for your answer. My problem is that I want the last word of the address, return it on the First Place and concatenate the other part of the address to return it after the First place. I don't know if it's clear , i put an example :  RUE GEORGES BONNAC would be BONNAC (RUE GEORGES).
Thanks Xander
XanderBakker
Hi KARIM LABIDI ,
if (cnt > 0) {
    } else {
        if (cnt2 > 1) {
        } else {
            return lastword;
} else {
} else {
    Console(words);
    if (cnt2 > 1) {
    } else {
        return lastword;
KARIMLABIDI
Yeah Xander it works perfectly. Thank you so much!
XanderBakker
Hi KARIM LABIDI ,
Glad to hear that it works. Could you mark the post as the correct answer? If you need any additional explanation just let me now.
KARIMLABIDI
Hi Xander,
do you know if it possible to add an element in the split? Sometimes , my strings are like this : AVENUE D'ARES so I need to keep ARES and not D'ARES. I would like find at the end :ARES (AVENUE D'). Do you know if it's possible to have this? Maybe with a replace for the ' by a " " but i'm not sure.
If you have a idea about this problem, I will be grateful.
XanderBakker
Hi kbm_admin ,
if (cnt > 0) {
    } else {
        Console(words);
        var add = "";
            lastword = arr[1];
        if (cnt2 > 1) {
        } else {
            return lastword;
} else {
KARIMLABIDI
Hi @XanderBakker,
yeah it works perfectly. Thank you so much. I very appreciate your help and your reactivity.
Thank a lot
