Read-only schema lock; project not open
5177
14
05-24-2022 12:14 PM
MattCotterill
I have an ArcGIS Pro project that will only open as read-only. I don't have it open anywhere else and I've tried closing everything and even restarting my computer.
Before this happened, I was migrating .mxd documents to Pro projects and feature classes from .mdb databases to .gdb databases
MattCotterill
ArcGIS Pro Indexing (Your_Username) has dropped out of the task scheduler library; still read only
DanPatterson
MVP Esteemed Contributor
and you might also want to try the operating system, by right-clicking on the aprx and checking its properties and untoggle any read-only setting.  it may be that once it is set, it can only be unset at the operating system level
... sort of retired...
MattCotterill
It's been unchecked this whole time. I just checked it on and opened the project, closed it, checked it off and reopened it. Still no dice
Robert_LeClair
Esri Esteemed Contributor
Back to the ArcGIS Pro options - at the very bottom of Indexing, click Delete Index and redo the workflows.  Still no dice?
MattCotterill
still no dice. I need to turn indexing back on to get it back in the task scheduler library so I can disable it in the task scheduler. then I go back into the options to uncheck the "update the index periodically" box and delete the index. still read only
