Re: Lidar Data Management
1507
08-18-2022 12:32 PM
ANDRESAVOIE
Hello everyone,
Im currently trying to convert a Las Dataset into a Raster. I have to much data for the simple : Las Dataset to Raster tool. From what I understand, my best option is now to use the function : Las Dataset to Tiled Raster. This geoprocessing tool is part of the 3D Sample Tools extensions. For some reason, when I input my Las Dataset into its box, this error message shows up :
ERROR 032659 updateParameters Syntax Error: File "C:\Program Files (x86)\3D Samples\Pro\3D Sample Tools.tbx#LasTileRaster_samples3d.UpdateParameters.py", line 35
else:
TabError: inconsistent use of tabs and spaces in indentation
I have the advanced personal use license with spatial and 3D analyst and I am using ArcGIS Pro.
If you have any idea how to fix this problem it would be greatly appreciated.
Thanks, Andre.
DanPatterson
MVP Esteemed Contributor
Perhaps use this
Convert LAS (Conversion)—ArcGIS Pro | Documentation
since the sample toolbox has been largely replaced by builtin Pro functionality, according to....
3D Sample Tools 3D Analysis Team - Esri Community
... sort of retired...
ANDRESAVOIE
Thank you for the response, the tool does seem retired. Im not sure how the convert las tool is supposed to help. Is it supposed to make the data less processing heavy for the computer? If this is the case im not sure it will be enough (6803Km2 of aerial lidar) but Ill give it a try.
DavidVidovic2
Hi, I have the same issue/question about the 3D Sample Tools - LAS to Tiled Raster. Did the convert las tool in Pro work for your large dataset?
DanPatterson
There are a load of other tools in ArcToolbox
An overview of the Point Cloud toolset—ArcGIS Pro | Documentation would be a good place to start, or
An overview of the LAS Dataset toolset—ArcGIS Pro | Documentation
search the help using "las" for many more
