Rasters disappear when new field is added
681
01-04-2024 12:16 PM
Labels (2)
Markbe_utco
I'm trying to create a derived mosaic dataset with two additional fields added to the attribute table.
Step 1: Use Create Mosaic Dataset tool to create empty derived mosaic dataset
Step 2: Use Add Rasters To Mosaic Dataset tool to add source mosaic datasets to new derived mosaic dataset
Step 3:  Open the new derived mosaic dataset attribute table and adjust MaxPS and ZOrder values for preferred display behavior.  The rasters display correctly at all scales.
Step 4: Open the Fields View for the attribute table, add a new field and save changes
It is at this point all the rasters disappear at all scales, the only thing visible is the green footprint outline.
If I delete the newly added attribute field the rasters reappear.
Any suggestions as to why this happens?
