Raster to Polygon: Polygons not in proper location (offset)
1508
10
04-04-2025 08:14 AM
NateLemoine
I am trying to create a polygon from a .tif raster. When I use the Raster to Polygon tool, the generated polygons are all offset to the north by quite a bit.
I am aware of all the projections/transformations. I have been through every layer/feature and they are all set to the same projection and coordinate system. When I create the polygons, I make sure to set the output coordinate system to the same as the input raster, I set the extent to the same as the input raster, and I use 'snap to raster' to snap to the input raster. Despite all of that, it still returns polygons that are offset into the wrong position. Can anyone help me out?
NateLemoine
Thanks all. I did send ESRI a message. But at least I know the workaround now.
