Raster gridcells change when geoprocessing (clipping)
1531
04-17-2023 05:53 AM
BramLoef
Hi y'all
When geoprocessing a raster, for example clipping or exporting my raster (or mosaic two rasters). The cells of the new raster deviate from the original one. This results in an offset between the corners of the tiff and this of the correctness of the raster. I include the snap raster and project the same coordinate system on the new raster. Still this gives the same problem. Who can help me out?
DanPatterson
Cell Size (Environment setting)—ArcGIS Pro | Documentation
Cell Size Projection Method (Environment setting)—ArcGIS Pro | Documentation
How the Cell Size Projection Method environment setting works—ArcGIS Pro | Documentation
A couple of links.
Every tool has an Environments tab, set your requirements for a tool run in there so that "defaults" don't get applied that you don't want.  When it comes to clipping, what are you using as the clip feature/raster?
snap raster, and the coordinate system are fine, but the small offsets can arise if other issues are at play.
The above link covers some of the issues, I will assume you have seen others as well.
... sort of retired...
