Raster dataset within file Geodatabase
1072
07-23-2024 11:10 PM
AndyIngall
I have created a raster dataset within a file geodatabase on a local machine.  There are quiet a few original jpg images which total around 7Gb in size.  However when I look at the created file geodatabase (which was created new) the size is 150Gb.
Can someone please explain how this could be.  I get that there will be some differences in size but 143Gb more....
DanPatterson
Image and raster data storage and management—ArcGIS Pro | Documentation
Under : Raster data storage model comparison
under : Cons
Depending on the file size and compression of the input images, the file size of the output may be much larger than the input data.
... sort of retired...
