raster data issue
1215
10-06-2022 09:43 AM
by Anonymous User
Not applicable
Hello,
I am new in general to GIS and am currently an intern working on learning the basics by doing a few projects. I learned on ArcGIS Pro in my classes though, my job uses ArcMap. I had ArcGIS Pro installed a few weeks later, and I'm attempting to open a geospatial database from ArcMap on PRO. I am looking at the same image on ArcMap and it for one loads unlike PRO, and for two the image on pro is almost white? Also, again, the same image is blurry. I've messed with the contrast and what not but cant find a solution, perhaps I'm missing something.
RhettZufelt
MVP Notable Contributor
Have you matched the display settings that you were using in ArcMap?
For imagery like that, Bilinear resampling normally works best.
Normally, if I set the strech, resample, etc. the same in Pro, will look very similar/same in ArcMap.
R_
by Anonymous User
Not applicable
Hello, thank you for your response. As I said I'm a bit new, when I select the data under map, I get the options for appearance, labeling, and data, not rendering. Ill attach a picture below.
RichlandGIS
I think you need to highlight the raster in the TOC so the Raster/Mosaic Layer menu shows.  That is where you find the rendering options.
R_
