Raster Calculations (precip - evapotranspiration)
971
02-27-2024 03:32 PM
Labels (2)
EmilySousa
Hi all- trying to get some assistance in knowing which direction to take this.
I have two rasters covering the same geographic area. One is precipitation and one is evapotranspiration. I am hoping to create a map of water availability (which would be precipitation minus evapotranspiration). Although I've been at it for a while, I still feel like a bit of a novice at ArcPro. Can someone help me figure out which way to go with this? Does this fall under raster calculator or is there a different sequence of tools I should use?
Thank you!
DanPatterson
MVP Esteemed Contributor
the synonym for subtract
Minus (Spatial Analyst)—ArcGIS Pro | Documentation
... sort of retired...
