"Add Database Server" like in ArcCatalog - is this still not possible in Pro?
6595
16
02-15-2023 08:33 AM
KG_427
Hello,
I came across this post that hasn't been updated for awhile: https://community.esri.com/t5/arcgis-pro-questions/manage-sql-server-express/td-p/403017/page/2
Is it still not possible to create a database server connection to manage Sql Express databases from directly in Pro?  We are attempting to migrate to Pro for everything and are concerned that this still doesn't appear to be an option in Pro.
Thanks.
TonyContreras_Frisco_TX
From the information in the Current Help documentation, it appears only ArcMap can create Workgroup geodatabases. You should be able to create a geodatabase connection (.sde file) to consume the data stored in workgroup with a user account that has permissions (using ArcGIS Desktop or ArcGIS Pro), then use that file in ArcGIS Pro to add the data to your project. More information on that here.
KG_427
Thanks for those, but it doesn't look like to me that it gives you the option to manage users.  Is there a plan to make this an option in Pro?
Robert_LeClair
Esri Esteemed Contributor
That I don't know Kim as I don't work on the ArcGIS Pro Development Teams rather I work for Training Services.  One option is to review existing ArcGIS Ideas to see if there is an idea to support this.  If there is not, then you can add a new idea.
by Anonymous User
Not applicable
@Robert_LeClair  404 error on your second link - can you relink please? Thank you.
Robert_LeClair
by Anonymous User
Not applicable
@KG_427 did you find an existing idea? @KoryKramer ?
by Anonymous User
Not applicable
Infuriating - I assume that Sql Express databases/ Workgroup is going away. Esri, official notification would be nice.
Robert_LeClair
So it seems that workgroup geodatabases can be used in ArcGIS Server and ArcMap according to this help document but cannot be created in ArcGIS Pro.
 @KoryKramer - can you provide additional information to AndreaB?
