Question for Deep Learning Coconut Tree tutorial
4560
11
02-17-2020 01:44 PM
WilliamHarbert
Hello,  I am working through the Deep Learning Coconut Tree tutorial and have a problem with the JupyterLab step.  I am not quite sure how to set the path in step [5] and have tried multiple variations.
Good News:  Everything works until the Jupyter Notebook step! See below--Export Training Data was successful.
Bad News: the prepare_data steps always fails! Please note that I launched jupyter-lab from C:\DeepLearning\Data
I'm not sure what the issue is here.   I noticed an earlier thread from last year with similar questions, which was unresolved I believe.
Any help would be greatly appreciated!  Thank you.
DanPatterson_Retired
you installed the prerequisites according to
Install deep learning frameworks for ArcGIS—Help | Documentation
WilliamHarbert
Dan,
I followed the directions in the training materials for this particular exercise: That step is titled:
Detect palm trees with a deep learning model
Clone the default conda environment
at this URL: https://learn.arcgis.com/en/projects/use-deep-learning-to-assess-palm-tree-health/
Use Deep Learning to Assess Palm Tree Health | Learn ArcGIS<https://learn.arcgis.com/en/projects/use-deep-learning-to-assess-palm-tree-health/>
Create training schema. Creating good training samples is essential when training a deep learning model, or any image classification model. It is also often the most time-consuming step in the process.
learn.arcgis.com
I'll follow the first installation and then retry this tutorial skipping the conda environment step.
My sincere thanks for this email!
Cheers,
Bill
WilliamHarbert
I created a new python image following these steps:
Please note that this installation order results in downgrading of two packages: libtiff and pytorch.
I then restarted ArcPro making sure that the correct Python image was active.  I reran the Export Training Data For Deep Learning step using the above python image.  This ran well with no errors.
I then started the required cmd window using the correct python image:  Please note that this is called DL_PalmDetection in my .
Excellent!
WilliamHarbert
Oh dear--another academic with old hardware--any suggestions here please?
I have a more modern machine I can run this on and am just checking--at least I'm not using my boss SUN ULTRA 40!
ArcGIS Pro 2.5 system requirements—ArcGIS Pro | Documentation
can you run it link
ignore the minimum spec, the next option should be considered the minimum
Days wasted * daily rate = amount you could have directed towards a new machine
WilliamHarbert
Excellent point, I'll move this circus to better hardware now--thanks again for the help!
WilliamHarbert
This works great on the more powerful GPU hardware, training chips are well displayed--Thanks a million!
so the documentation link worked then (?)
WilliamHarbert
Yes, with the hardware update--everything worked perfectly.  I'm really impressed, this is amazing.
