Question about Labels issues
494
03-25-2026 08:15 AM
DEAF_PROBERT_68
Honored Contributor
I have a question for those that experience with labels issues.
I have a datasets that was already prepared and pre-set .
So when you use Task or clip from the original dataset.
One of things I do was to check for labels to ensure it runs smooth...
However, I found three of the layers has the error..
Here is the example of one of the layers I came across is
Error 1 as example:
Does it mean the Expression itself does not recongize from the attributes ?
Thanks
DEAF_PROBERT_68
Honored Contributor
I test 2 out of 3 layers and fixed it. It's because of the error I believe was in python code. I change it to Arcade and it seems to be working again..
DEAF_PROBERT_68
Honored Contributor
Ok.  The 3rd layer is fixed. The layer is PLSS BLM First Diversion and the error that had the error “Drawing Alerts".
So, I looked into the layer's label and found out that "Sections" python did not work properly.
So, I duplicate the Label class "Sections" to PB.  The PB is the one that had the error.
In the Sections label, I use the expression to set "Is Not Equal" to PB
then in the PB Label class, I use the expression to set to "Is Equal" to PB
Then I went back to find the PLSS Basemap from the Living Atlas and review it...
So that is how I fixed the problem.  PHEW
That is my summary.
