Python script question
1755
6
10-23-2024 11:27 AM
JRR
UseThis = 2
arcpy.SelectLayerByLocation_management("BIRDLINE_LAYER", "intersect", "BigPoly", 0, "new_selection")
arcpy.SelectLayerByAttribute_management('BIRDLINE_LAYER', 'SUBSET_SELECTION', '"Route" = 2')
#arcpy.SelectLayerByAttribute_management('BIRDLINE_LAYER', 'SUBSET_SELECTION', '"Route" = UseThis')
#arcpy.SelectLayerByAttribute_management('BIRDLINE_LAYER', 'SUBSET_SELECTION', "UseThis" )
Only the first 'SUBSET_SELECTION', works.   How can I use the value of 'UseThis' ??
CodyPatterson
MVP Regular Contributor
Hey @JRR
I think you need to pass the input as a function string:
UseThis = 2
arcpy.SelectLayerByAttribute_management('BIRDLINE_LAYER', 'SUBSET_SELECTION', f'"Route" = {UseThis}')
Cody
JRR
That seems to only apply to rasters.  Thanks for your response!
show invalid expression
CodyPatterson
Hey @JRR
Ah alright I see, it may be because your Route attribute is expected to be a certain data type, if it's an integer it would be something like this:
Otherwise, if it is a string, it should be this here:
arcpy.SelectLayerByAttribute_management('BIRDLINE_LAYER', 'SUBSET_SELECTION', f'"Route" = \'{UseThis}\'')
This escapes the single quotes to be used in the SQL. Hopefully this solves it for you!
Cody
JRR
Neither of these lines work.
CodyPatterson
Hey @JRR
The errors are not very descriptive using IDLE, you may have better luck and better error reporting when using Visual Studio Code instead.
Give this a shot here, this builds the query outside of the function:
UseThis = 2
sql_expression = f'"Route" = {UseThis}'
print(sql_expression) # Just use this to test to see if it's actually printing anything and that the expression looks correct
arcpy.SelectLayerByAttribute_management('BIRDLINE_LAYER', 'SUBSET_SELECTION', sql_expression)
I would ensure that the print statement is in there for debugging.
Cody
JRR
I tried with no success.   Sorry to be so late in responding.. traveling.
Sent the code and a sample data set.
