Publishing mosaic dataset as web map
1075
11-25-2022 03:28 AM
bogdanpalade2
Hi!
One simple question. In ArcGIS Pro, I am trying to publish just the footprints of a mosaic dataset as a web layer. I found that impossible. Further on, I inserted the mosaic dataset in a map and tried to publish it as a web map. It publishes the "Boundary" and "Image" layers but not the "Footprints". Am I missing something here?
Cheers!
RhettZufelt
MVP Notable Contributor
You can use Export Mosaic Dataset Geometry to export the Footprints as a feature class, then publish that FC on the web.
R_
bogdanpalade2
That would not be a solution as you need to do it everytime the mosaic dataset changes. I was looking more to something like a service.
Regarding the footprints missing, it looks like this only happens with referenced MDs. With source, or derived MD, this problem does not happen.
