Publishing from ArcGIS Pro 2.8 no data in map service
3463
9
06-21-2021 08:54 PM
LaraRector
Hello,
Has anyone else come across an issue when publishing a map service from ArcGIS Pro 2.8 that polygon layers publish with no data?
Lara
JayantaPoddar
Could you share what workflow you for following for publishing the map service?
What is the version of your ArcGIS Server?
Is it a stand-alone Server or the Server is federated with Portal for ArcGIS (ArcGIS Enterprise)?
Have you registered the underlying geodatabase/ folder with Server?
Check Publish a Map Service from ArcGIS Pro for more details.
Think Location
LaraRector
I have 4 layers 1xpoint, 1xline and 2x polygon which both reference the same data source
ArcGIS Server: 10.81 federated
Yes we have a registered geodatabase that I am publishing from. But have also just noticed that I am also getting this error from a hosted feature class that I published recently.
Getting this error in dev tools: Error querying server for feature count in MapTextProvider: Error: Failed to execute query.
We're still trying different things to resolve it so I'll post again if we work it out otherwise we might need to log a ticket with support.
JayantaPoddar
You cannot publish a map service to a federated server using ArcGIS Pro.
Instead, check if you can share them as web layers (individually) or as webmap to your ArcGIS Enterprise. Sharing Web Layers
Think Location
LaraRector
Sorry, maybe I called it the wrong thing.  It is creating a service.  I use Share > web layer > overwrite web layer
The same process worked with no problems on production where we still have 2.7 installed.  I will log an ESRI request as we have to get to the bottom of this issue to make sure it doesn't occur on production.
We just uninstalled 2.8, reinstalled 2.7 on the server then we had to get the version of the arpx from production (that had never been opened in 2.8) we published that (using the process above) and everything is back again.
CarolynMilland
We are having the same problem and, on top of that, we cant publish a feature layer to our portal using arcgis PRO 2.8
Is this a known bug? or do you have a fix?
LaraRector
CarolynMilland
OFFICIAL
No, the error was not this issue. Our portal is 10.7.1, plus the error was different to the one listed in the link you passed along.
Regards,
Carolyn Milland
Geospatial Intelligence Analyst | Geospatial Intelligence Unit
Online and Geospatial Intelligence Section
Intelligence Enabling & Governance Branch | Intelligence Division
Strategy and National Resilience
Department of Home Affairs
P: 02 6229 3874
Email: [email protected]
LaraRector
sorry the bug we had was this one.  We are still publishing using 2.7.4 as far as I know
BUG-000138634
Unable to publish Azure PostgreSQL referenced data to ArcGIS Enterprise from ArcGIS Pro 2.7.x.
CarolynMilland
OFFICIAL
It's strange as we are just publishing directly from a local gdb. On top of that, we can't publish a feature service at all. Is this fixed in 2.9? At the moment our solution is to use 2.6 to publish but I'd prefer to be able to upgrade. Does 2.9 solve these issues?
Regards,
Carolyn Milland
P: 02 6229 3874
