Published Feature Layer and it shows up as a Table
2293
02-23-2021 04:06 AM
burrkim
I'm publishing a bunch of feature classes to ArcGIS Online and half have published as a feature layer and the other half as a Table.
I've repaired the Geometry, still a table.
I've published from another GDB, still a table.
Nothing works and I can't find this as an issue online. Can someone please help ASAP?
Thanks
MervynLotter
MVP Regular Contributor
I reported this as a bug during the Beta testing and it relates to new symbology and transparency used in Pro 2.7. But the problem is bigger than Pro alone as it requires fixing in AGOL too.
The solution is to turn off all layer transparency before publishing to AGOL (worked for me).
Best of luck.
MervynLotter
Best of luck.
burrkim
Perfect!
Worked right away. Thank you
Gisbert61
This saved my day, thanks Mervyn
