Proximity
2190
07-29-2021 06:48 AM
CanJM
How to  identifying assets (poles) in proximity to storm drains/manholes (oil leaking risks) and hydrants. I do not have a distance. I cannot use the buffer tool. Is their any tool in arcpro that can be used to do proximity analysis.
RPGIS
by MVP Regular Contributor
You should be able to add those features as well to the tool. Did you add all of those features or only the specific features.
Also, when you ask 'add switches and transformers with poles', are you asking on how to specify those features that have poles attached or do the poles have those specific attributes. In either case, you would want to select the poles (or other features) by those attributes and then run the tool.
RPGIS
You can use the Near tool to figure out how close features are to other features.
CanJM
I ran it. I selected the input features to pole and near feature I selected all the manhole, storm culvert , storm conduit. Method - Planar. It populated the property and field name itself. It said complete however, I want to add switches , transformers with poles.
How can I use near tool?
RPGIS
CanJM
I only add the poles and no other feature.  I noticed every pole is nearby a sanitary manhole or culvert.  This is making me question the accuracy. Thank You for telling me about this tool. I appreciate it.
