Process metadata using XSLT transformations
985
05-12-2021 07:53 AM
vojtech_hribal
Hi, I used the Process metadata using XSLT transformations tool in Arcgis Desktop to override the revision date in the metadata. Unfortunately, I did not find it in Argis Pro. Would it be possible to add it? Thank you
JoeBorgione
Arcgis Pro metadata does not use the XLST transformation. Are you suggesting an idea for it?
