Problems with hillshades on latest version of ArcGIS Pro
2139
6
01-18-2025 08:14 AM
JimScurry
Has anyone had a problem with bizarre hillshade generation in ArcGIS Pro 3.4?   I recently downloaded 2019 DEMs from USGS.  My previous data was 2008 with both DEMs and hillshades generated directly from LAS point clouds.  This time USGS already had DEMs so I figured why go through the process of building a DEM if they already exist?
The DEM seems to be fine but when I generate the hillshade from that DEM, I get a weird waffle iron effect and data voids.  The DEM clearly indicates that elevation data are there but querying the hillshade returns a no data value.  Below is a screenshot of the DEM shaded red and hillshade in greyscale.  As is evident, the DEM shows through the no data areas.  Never had this issue before.  I tried generating the hillshade from Spatial Analyst, 3D Analyst and the Raster Function and export.  I assume they all call the same subroutine but tried anyway,  There is no difference.
Has anyone seen this or have any suggestions?
Thanks, Jim
DavidPike
MVP Notable Contributor
What's the coordinate system of the data and your Map Frame?  Possibly an issue with not being in a planimetric CRS.
AndrewHankinson
Hi @JimScurry
Did you get to the bottom of this? I have experienced the same issue and only recently. The issue is especially obvious when running flow direction and curvature processes.
The DTM I am working with is projected to British National Grid 27700, as is my project, the strange thing is I  mentioned this to the supplier of the DTM and he has ran it in QGIS and doesn't get the same output with this gridded effect occurring.
AndrewHankinson_0-1754960986699.pngAndrewHankinson_1-1754961009517.pngAndrewHankinson_2-1754961028951.png
JimScurry
Andrew,
I have not gotten to the bottom of the issue.  I have recruited other colleagues to try to process the data; some using other software to determine if it is a data issue, an ESRI software issue or an issue with my system and installation.
I have had to put it on the back burner because of other projects but still have it on my list.
Jim
AndrewHankinson
Hi Jim,
Thanks for getting back to me, I will let you know if I find anything out.
LeahBeltran
Hi all,
I know this is a year later but did either of you figure out the issue? I am currently experiencing something similar.
Best,
Leah
JimScurry
I never got a resolution.
