Problem with the tool ´dispers markers`
1086
11-24-2022 11:25 PM
SebastianHänsel
Unfortunately, I have problems using the 'dispers marker' tool in ArcGIS Pro 3.0.2. I would like to rearrange overlapping points (simple point feature, feature class in file geodatabase) using the tool. In the past, this has already worked with the same datasets (always copies of the original data), although it often required a few attempts (without changing the parameters!). According to the status display, the operation is currently being carried out successfully, but it does not lead to any visible result. I chose the Undo option for the operation. But even without this option, the operation will be executed successfully, but also with no result. Apparently, the tool doesn't perform any operation at all. After the application, you can see a brief "flashing" of the points on the map on the screen. However, since the operation cannot be undone via "Undo" in the toolbar (quick access), I assume that the tool is not working at all.
I would be very happy about tips on what could be causing this.
Thank you
Sebastian
Brenda_Thompson
I am experiencing the same issue... no matter what environment or parameter settings I use, there are no visible changes to the data displayed, even though the operation seems to have been completed.
