Problem with Legend showing unchecked items after printing that were not showing in the Layout
4380
12-30-2020 09:25 AM
JustinJohnston
I am having trouble with my legend.  In my layout, the Legend displays exactly the way I want it to display.  However, when I print, it expands the legend to include an "Image Red: Band_1" that isn't shown in the layout. It even reshuffles the columns to fit it in as if it was shown in the Layout. I checked the Legend list for the Layout, and the box next to "Image" is not checked, so should not be shown and should not print.  Seems like a bug to me.  This is the second time this has happened and on different projects.  Both occasions, it was forcing the legend to print a service layer (background aerial imagery).
Cheers,
Justin
JustinJohnston
I posted in that thread a solution that I found.  When I had the legend created without the offending map service layer, I opened the legend Options, expanded Synchronize with map, and cleared all 4 options there.  When I printed, it did not include the offending map service layer in the legend!
Cheers,
Justin
DavidPike
MVP Notable Contributor
Seems to be a few workarounds listed here - Unwanted Legend Item Appears After Export - GeoNet, The Esri Community
worth a go.
JustinJohnston
I thought that would work, but did not.  The solution there was to create a new legend by first selecting the layers in the content pain and then creating the legend.  I did that and the image layer did not show up in the legend in the layout, but still showed up when I printed.  It sounds exactly like my problem on that thread though.
JustinJohnston
Cheers,
Justin
