Problem with EVI calculation using Sentinel 2A data
128
Monday
Labels (2)
NorbertNieścior
I'm using ArcGIS Pro 3.5.0 I've got downloaded Sentinel 2A data, and I used raster calculator to calculate EVI. However, my results are outside of the -1 to 1 range, and the image it produces is very strange.
I use the code from ArcGIS Pro for the calculation of EVI. I had B2 as the blue band, B4 as the red band, and B8 as the NIR band. I based this code off of the general formula for EVI., which is.
However, when I enter this, I get a range of -3355 to 2370, and from the image I cannot differentiate anything.
Any advice on why this might be would be greatly appreciated.
DanPatterson
you are missing the calculation expression in your question
Was it the one used in
Solved: EVI calculation with Sentinel 2A data - Esri Community
... sort of retired...
RichardDaniels
MVP Regular Contributor
To obtain an index result range of -1 to 1 the results have to be normalized or the equation itself setup to return the result in a -1 to 1 range.  The equation does contain constraints to ensure this happens. That means the input bands are assumed to be normalized prior to use. See Dan's comments on how to do that.
