Problem with bar charts in 3.5
360
3 weeks ago
FranziskaSumpf
I am facing some problems with bar charts using the split by option. Instead of splitting the data by the chosen field, I just get duplicates.
This did not happen before! I got a new laptop with ArcGIS Pro 3.5.2. Not sure what the old one had, I think it was 3.4.x.
The error seems to be the same as in this post, where it occurred in 3.4 with scatter plots. However, that thread does not offer any solution.
I have narrowed it down a little bit, as the error only occurs when the layer has a join to another table. And it does not matter whether I chose fields from the original table or the joined table.
I have tried in a different project and with different data, the results are the same.
Has anyone else had this problem? How did you solve it? Or is it a bug? Has it been addressed? Any help is welcome! (I rely on bar charts a lot)
ChristopherAllen
Hi @FranziskaSumpf ,
Thanks for reporting this! I can reproduce this bug going back to 3.5 and it appears that it's caused by the join so appreciate that you added that detail. This will be fixed in the upcoming 3.7 release, and we're aiming to also add the fix to the next 3.5 and 3.6 patch updates. In the meantime, if you're able to alter the input layer, you might consider using the Join Field tool to make the join permanent--the chart should work in that case.
Take care,
Chris
ChristopherAllen
Take care,
Chris
FranziskaSumpf
Thank you, @ChristopherAllen, for the confirmation that this is a bug. Does it have a BUG Number I can watch out for? And I hope you can get the fix into one of the patches, because right now I am not sure when and if we will be able to move beyond 3.6 (due to the licensing changes).
ChristopherAllen
Here's the BUG link:
https://support.esri.com/en-us/bug/charts-with-the-split-by-option-do-not-display-correctl-bug-00018...
Once it's patched in 3.6, a note should be added to Version Fixed.
Take care,
Chris
