Problem with AGP Python Toolbox executing Unittest
1842
10-24-2023 01:35 AM
BernhardEhrminger
In Module FileCount.py I have a simple Python Unittest, which tests that the number of files in current directory is greater than zero, so the test should never fail.
import unittest
import pathlib
class Test(unittest.TestCase):
    def setUp(self):
        pass
    def tearDown(self):
        pass
    def test_file_count(self):
        self.assertGreater(
            len(list(pathlib.Path().cwd().glob('*'))), 0)
        pass
The Python Tool-Class referencing the Unittest is like:
class DemoUnittest(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Demo_Unittest"
        self.description = "Execute a Unittest"
        self.canRunInBackground = True
    def getParameterInfo(self):
        """Define parameter definitions"""
        params = None
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal validation is performed.  This method is called whenever a parameter has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        try:
            self.result = unittest.TextTestRunner().run(
                unittest.TestLoader().loadTestsFromModule(
                    module = FileCount))
            arcpy.AddMessage(self.result)
        except Exception as e:
            arcpy.AddMessage(str(e))
        return True
    def postExecute(self, parameters):
        """This method takes place after outputs are processed and added to the display."""
        return
When running the Python Tool in ArcGIS Pro I get the following result:
So from the screen dump above, I conclude the Unittest performed as expected (OK).
But why is ArcGIS Pro telling me erroneously  "Failed to execute (DemoUnittest)"?
Thank You for your attention.
BernhardEhrminger
the class constructor unittest.TextTestRunner has an argument stream, which can be initialized to sys.stdout. In this case the problem with failing tools does not exist.
Luke_Pinner
MVP Regular Contributor
The default output stream for unittest.TextTestRunner is sys.stderr and I don't know and haven't tested, but  perhaps ArcGIS notices this and assumes there's been an error?
BernhardEhrminger
BernhardEhrminger
thank you Luke, the situation is like you pointed out.
