Probability Based Analysis?
780
11-26-2025 07:03 PM
Labels (3)
ArchTim
I'm on Arc GIS Pro - and I'm looking for a tool that can create a layer that includes probabilities. At a fundamental level I would like to create H3 Hexagons and have a model assign probabilities of finding an object within those hexagons based on specific spatial criteria. I only know a general area of  where the object is so it would be helpful to be able to update the probabilities based on not finding the object within a hexagon.
Does the software have any capability for this type of analysis?
Thank you so much for your help!
DanPatterson
MVP Esteemed Contributor
Tessalations are available in
Generate Tessellation (Data Management)—ArcGIS Pro | Documentation
Have you ruled out what is available in the Spatial Statistics extension?
Some specific examples may guide further suggestions.
An overview of the Spatial Statistics toolbox—ArcGIS Pro | Documentation
... sort of retired...
georgerobert
I’ve dealt with this in ArcGIS Pro before, and yeah, you can build H3-style hex grids and run a probability model on them. Using Spatial Analyst and ModelBuilder, you can update probabilities as you clear each hexagon, which really helps narrow down search zones. It takes a little setup, but it definitely works kind of like how APK makes editing easier once you know the tools. Hope this helps, it saved me a lot of time too.
