import Arcpy error after upgrade from 2.9 to 3.1
2411
5
08-24-2023 06:20 AM
DavideBollo
Configuration:
Windows 10 Pro
Version 22H2
Os Build 19045.3393
tried to import library from python command prompt, getting the error:
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>python
Python 3.9.16 [MSC v.1931 64 bit (AMD64)] :: Anaconda, Inc. on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import arcpy
  File "<stdin>", line 1, in <module>
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 77, in <module>
    from arcpy.geoprocessing import gp
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
    from ._base import *
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
    import arcgisscripting
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
    from ._arcgisscripting import *
ImportError: DLL load failed while importing _arcgisscripting: The specified procedure could not be found.
follow DarrenConly instructions without success:
https://community.esri.com/t5/arcgis-pro-questions/importerror-dll-load-failed-while-importing/m-p/1...
Tried many solution found on web...
added to global environment variable "PATH":
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgisscripting
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts
added to global environment variable "PYTHONPATH":
Clear installation
No Arcmap Installed
No QGis Installed
No other python environment installed
No VScode or other IDE installed
Unable to create cloned workspace (with arcgis or conda command prompt)
I don't know how to solve...
thanks in advance
DavideBollo
solved (but is not a solution)...format system disk and reinstalled everything...
DavideBollo
new update...after installing 3.1.3 patch...nothing works again...
ShariF
So frustrating. Did you ever get arcpy to work? I'm getting the same error when I use regular or cloned environment in PyCharm.
https://www.linkedin.com/in/shariforbes/
DavideBollo
now I'm with ArcGIS Pro 3.2.1, win10.
after serveral attemps, formatting my machine several times, I discovered a conflict with an electronic signature software.
if I install the 64bit version of this software, the arcpy libraries outside of ArcGIS no longer work.
maybe you also have software that conflicts with the libraries.
AndyHodren2
I had the same problem.  Ended up solving it by re-ordering the import statements.
Originally I had:
import pandas
import os.path
import arcpy
And I got
import arcpy
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
Then I changed it to:
import arcpy
import pandas
import os.path
And it worked fine.
