Pro2.7 - connect two point feature classes with lines
1450
06-28-2021 02:48 PM
TXgeo
In Pro2.7, I'd like to connect two point feature classes with lines using a Field common to both.  In the particular case, I have a feature with oil well bottom hole locations, and another with surface hole locations - these are directional drilled holes.  Both have a common ID number.
(1 year user).  Thanks for any help.
DanPatterson
MVP Esteemed Contributor
one idea, since they have the same id, is to join the tables,
make sure that the x, y coordinates are calculated in each featureclass's tables, then you can use
XY To Line (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
