Pro Traverse Finish button
2111
03-29-2024 03:32 PM
TonyAlmeida
MVP Regular Contributor
I've noticed that when activating the traverse tool, depending on what layer you have selected the "Finished" button is there or not there. I can't find a reason why it's there on one layer then not there on another layer. For example I have two layers that are both polyline layers, but has the "Finished" button, but when I select the other the Finished button is gone. What is the reason?
RobertLanio
Hi TonyAlmeida , did you find resolution for this issue?
PamCarver
PamCarver_0-1726497977057.png  FINISH
It's not quite the same as the old finish button that would leave the lines selected and ready to move.  It seems to work OK.  I have to activate this menu every time I use traverse by clicking on the "create a line feature" tool.  It should automatically open when you click "set start", that will be the next thing to figure out
PamCarver
HELP! I am just starting to test a parcel data move from ArcMap to ArcPro so I may be missing something.  We are also trying to use COGO Traverse. We have always plotted deeds and surveys into a line layer (we call traverse) . If I set the layer to polygon I have a finish button. If I change to my line layer the finish button disappears. Is this some kind of default setting that needs to be changed? I changed the default setting under options for Angular Units to degrees minutes and seconds, is there anything else that needs to be changed.  We never plot deeds into a polygon layer 😞
