Pro license from portal does not work
980
10-18-2017 04:53 AM
ModyBuchbinder
We have portal 10.5 with valid pro license that was assign to user X
We have pro 2.0 installed on a different machine.
Pro is working when it is taking license from on-line.
When we try to start pro using portal license if we try to login as user Y we get error that this user is not licensed for portal.
If we login as X pro just shut down.
In the portal we can see that user X just used pro license.
We found log file in C:\Users\USER\AppData\Local\ESRI_Licensing\Logs
That have this message:
-- Creating if not present/ overwriting lss.dat file as a task of saving session state for https://www.arcgis.com/ portal
bWorkingWithLicensingSrv = true
Offline mode = false
bLicenseSessionPresent = false
Any idea?
