Pro Featue Class to Feature Class tool fails
1736
03-04-2021 06:11 AM
MehrshadNourani2
The tool Feature Class to Feature Class tool fails to download from a Rest End URL. I get the following error: 000210: Cannot create output - failed to execute. Download location is a gdb created by Pro. It also failed to download as a shapefile and changed the download name to be the same as map service. I have Pro 2.6. All folders are located on my C drive.
I would be grateful if anyone has a solution.
Thank you,
Mehrshad
U.S. Census Bureau
DavidPike
MVP Notable Contributor
Does it not need to be a feature service rest URL?
JakeSkinner
Esri Esteemed Contributor
Hi @MehrshadNourani2 ,
You may want to give the following tool a try:
https://community.esri.com/t5/arcgis-online-documents/download-arcgis-online-feature-service-or-arcg...
I've had success with this when Pro's feature class to feature class fails.
MehrshadNourani2
Hi Jake,
I will give it a try. Actually, I am fan of the download tool you created! I have been using it for a number of years and it has been working great! We are moving our projects to Pro and want to test the new tools in Pro, hoping it would work. Any ideas why Feature Class to Feature Class tool is not working?
Thank you for your help!
Mehrshad
