Pro 3.1 Installer keeps asking for Desktop runtime 6.0.5 or greater. Installed x64 6.0.16 confirmed install and rebooted. Installer still wants desktop runtime installed. I am on a trial and really not impressed. What is ArcGIS looking for to indicate desktop runtime is installed? Does it fail is previous desktop runtime versions are installed?
Peter
This URL provides a link to the required installation and documents the issue you might be experiencing: https://esriaustraliatechblog.wordpress.com/2022/10/17/faq-addressing-arcgis-pro-3-0-microsoft-net-d...
Brian Baldwin, Esri Inc., Lead Solution Engineerhey Brian,
it seems the installer for ArcGIS is not identifying the install of the desktop runtime correctly for many people, especially if they try use SCCM for deployment. I'd expect the installer should be looking in Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\dotnet\Setup\InstalledVersions\x64\sharedfx\Microsoft.NETCore.App for the version above 6.0.18 - could it be that the logic is looking at that field as 6.0.18 is less than 5, as it's reading as 1<5, not 18 because it's a alpha string?
I have the same issue. reinstalling dotnet makes no difference.
I feel that I'm messing in the bowels of my computer with trying to fix the .net issue. My regular Pro version crashes always, so I tried my school version and it crashes.
For me, it seems I think my sccm deployment of the .net desktop is the issue - manually fine, but if deployed automatically, ArcGIS is not seeing what it needs to check install. I wonder if we can hack the msi for arcgis to say it's already installed?
