Pro 3.1.1 crash when opening a project
1609
05-22-2023 04:57 AM
tapatsysmc
We have moved our team from 2.9.5 to 3.1.1. everybody is fine and working but one!
he is opening a project that was created in 2.9.5 and arc pro crashes.
This only happens when opening a project that was created a month earlier in 2.9.5 ver.
When creating a new project it works fine.
I am looking for ideas!!!
David_McRitchie
It is a difficult one to say. Have they tried this for any other projects?
If possible they could export the Project in 2.9.5 to a Project Package via the Share tab and test opening this at 3.x.
I suspect it is a File or data connection that might be causing this hence creating a new Project is working.
Esri UK -Technical Support Analyst
tapatsysmc
Thank u for the answer.
We have moved 10 people from 2.9.5 to 3.1.1 and 9 are ok. only one has the problem.
Everyone else works just fine.
I have check 5 other projects on that computer and all are causing the crash.
I have a suspicion that the problem is a bad framework installation. I will check it today and report here after.
David_McRitchie
In that case, usually a clean reinstall resolves these issues.
This blog from Esri Austrailia provides a quick list of steps that can be used.
