Pro 2.7 - Change map coordinate display precision
2703
06-04-2021 08:34 AM
KeithAddison1
I need to have two decimal places for the seconds in the coordinate tracker in the map view, the thing that tells your the coordinates of the cursor.  Where can I change that?
JayantaPoddar
Did you change it under location units > Degree Minute Second? How does your option page look (screenshot)?
Does Refreshing the map help?
Is an upgrade to 2.8, an option?
Think Location
JayantaPoddar
From the location view dropdown
Under Location Units > Right-click on the particular value (Format Column)
Change Decimal places
Ensure DMS is marked as default
Think Location
KeithAddison1
The Format Location Units in the drop down doesn't seem to show up in 2.7.  I can set the DMS units through the options to 2 decimal places, but the coordinate tracker still doesn't and decimals for the seconds.
JayantaPoddar
Think Location
KeithAddison1
It showed up correctly after a reset.  The unit type changes instantly without restart but apparently precision sometimes needs a program reboot to show up.
