Precondition as an either or?
1121
09-13-2021 07:26 PM
AustinGootee
Anyone have an idea on how to setup an either or type precondition? I have two work flows that lead to the same raster: c_raster, but because of the workflows they end up with two different variable names. In the case of the picture below it's C_raster and C_Raster.
In the next step the C_raster's physical file path is used in the mosaic tool; however, i need to setup a precondition that make sure the c_raster is created before the mosaic tool runs otherwise i get an incorrect output. Any idea on how to make it so whether the c_Raster precondition or the c_raster's precondition is true that the mosaic will work? If both are added as preconditions the mosaic won't operate because one will inevitable always be false.Capture.PNG
DanPatterson
MVP Esteemed Contributor
Preconditions—ArcGIS Pro | Documentation  I think, if only one of the preconditions are met (you can have multiple preconditions.  You may need to use if-else logic to see if one or the other is met
... sort of retired...
