postgresql schema name limits
1062
07-10-2020 08:42 PM
yosukekimura
Hello,
Is there any limitation for name of schema allowed to be used?  I have PostGIS database, and when I make schema name be extremely short (less than 8?)  i can see it from ArcGISPro'd catalogue.  But longer schema name appears to hide contents in the schema.
Tags (1)
George_Thompson
Esri Notable Contributor
I do not think there is a limitation on the schema name; Enterprise geodatabase size and name limits—Manage geodatabases in SQL Server | Documentation
I would guess that the ArcGIS Pro UI is making the table name available based on the UI size.
I would contact technical support and have an analyst take a look.
Geodatabase
--- George T.
