All,
There are 2 current 2.7 Layout issues that I would like to update everyone on.
Issue 1: Pro Crashes
We believe this issue has to do with a combination of non-English OS and Spell checking enabled. We also believe that a possible work-around is to disable Spell checking. Here is the relevant help topic - https://pro.arcgis.com/en/pro-app/latest/get-started/proofing-options.htm.
Though we are still working on getting a dependable reproducible case, and need one to validate any fix, we are fairly confident based on the crash dump information that the work-around can help.
This also covered in the following thread: https://community.esri.com/t5/arcgis-pro-questions/pro-crashes-after-adding-text-to-layout-and-annoy...
Issue 2: Failure to open Layout View
The following message appears when opening a layout view.
We are trying to get a reproducible case to investigate this further. It may be related to Spell Check and for those running into this issue it may be worth it to disable Spell Checking. As we have been unable to reproduce the issue we cannot confirm the work-around.
Please let us know if this works or does not work.
Hopefully this new information can help some of you get around this issue until we have a fix. Thanks to all of you that have submitted crash dumps - it has really helped us get started on a fix. I'd also like to thank those of you who have logged an issue with Support. Being able to reproduce an issue is the most important thing to understanding the issue and engineering the proper fix.
Thanks for your patience.
Tom
