Pop-Up Attributes
4589
06-04-2024 09:16 AM
Janet_Wentz
ArcGIS Pro Version 3.3
When I click on an item on my map, a pop up window opens. I have added a ton of attributes to the attribute table. Last week something happened and now when my pop up window opens there is no attribute information. *I have added all the gravel hauled by the County Highway crews to the map. In the attributes I have how many cubic yards, type of gravel, location, etc... previously when the pop up window opened I could see that info. Now it is gone.
I would like that back! I did search how the pop up window attributes are added to the window. I cant seem to figure it out.
Any wisdom appreciated!
Thank you!
BarryNorthey
In the Configure Pop-ups pane, make sure that the Fields are added. This is the default but might have failed.
I inadvertently clicked Hide Bottom in the Pop-up pane and had to click it again to restore.
Hope that helps.
BarryNorthey
Hope that helps.
Janet_Wentz
Thank you so much for answering....
In the pop up window I dont even have that Hide Bottom option. I have added photo attachments of County Gravel Pits and Bridges... it shows the attachment but can not be accessed.
BarryNorthey
The Pop-up pane is divisible into two parts, either horizontally or vertically. The "divider" is sometimes at the bottom or side of the pane and doesn't stand out color wise. Hover the cursor over the darker bar at the bottom of the pane and the hide and split icons should appear. Drag the bar up to expose the contents of the lower part of your pane.
hduong
I hope you find solution, here is what I found. Mouse over the bottom of the pop up window, it will shows the Hide Bottom.
HassanEljaji
I'm having the same issues with pop-ups. Is this a bug in the release of 3.3? I attempted to configure the pop-ups and the best I can do is list the attributes without any formatting to include the field name.
