Poor trace performance when creating/modifying features in ArcGIS Pro 3.0?
4553
7
07-08-2022 01:19 PM
wayfaringrob
Honored Contributor
I'm wondering if anyone else has experienced very slow tracing since updating to ArcGIS Pro 3.0? Every time I go to create a new feature with the trace tool, I'll click on my first snapped point, move the mouse, and wait ages for the dashed line to show up if at all. I often trace roadway features which usually requires a lot of zooming, panning, and detangling, and the lag persists during all of this as well. Because of how long it takes for the dashed feature line to appear, I originally thought tracing was just broken altogether; it seems it's just very slow in 3.0.
Has anyone else come across this?
2 Solutions
Scott_Harris
@wayfaringrob I followed up on the case and it looks like there was a missing spatial index causing performance problems. In a future release there are plans to improve the ability in diagnosing these types of performance problems from within the software.
wayfaringrob
Honored Contributor
nice! In the meantime if anyone comes across this -- check the spatial index of ALL layers in your map, even if it's not one that you're editing, snapping to, or even have turned on. In my case I had a reference layer that just happened to be in my map that was causing issues and building a spatial index solved the problem.
Scott_Harris
Hi @wayfaringrob
We haven't heard that feedback about Pro 3.0.
Maybe clearing the cache or some of the other performance tips listed in this article will help? - https://community.esri.com/t5/arcgis-pro-documents/troubleshooting-performance-issues-in-arcgis-pro/...
One tip: only snappable layers are traceable, perhaps checking off some layers in List By Snapping in Contents pane would help?
If you continue to experience performance issues with snapping, please consider sharing your workflow and some sample data that reproduces the issue with Esri Technical Support.
Scott
wayfaringrob
Honored Contributor
Any other reports of this happening? I've done a complete reinstallation of Pro and still face this issue from project to project, dataset to dataset. It becomes unusably slow whenever I'm actively tracing a feature -- see below.
(view in My Videos)
Scott_Harris
@wayfaringrob No, we have not received feedback about Trace performance in ArcGIS Pro 3.0. What you show in the video is unacceptable performance and requires further investigation. Have you reached out to Esri Technical Support? If so, is there a case number that we can investigate/follow?
wayfaringrob
Honored Contributor
Thanks for confirming. I haven't had the time to work through a support case but it does seem that that is the last remaining option; I had our IT look at my graphics drivers and everything today and we cannot figure out the issue. I've opened an Esri ticket.
Scott_Harris
wayfaringrob
Honored Contributor
casjone
i've experienced the same thing in 3.3. i'm going to check spatial indexes now though.
