Polygons to Points
2320
10-15-2021 07:32 AM
MichaelPickens
Is their a way to take Polygons and make them into points where they have to stay within the boundaries.  When I do this for tracts they fall outside of the boundaries and if I go to spatially join them again then it misses those points.
I have the worst time trying to relate anything using tractids so this would be very useful.
DataOfficer
Use Feature To Pointhttps://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/feature-to-point.htm
Tick the Inside option to keep the point within the polygon (where a centroid would otherwise fall outside of the polygon).
DataOfficer
MichaelPickens
That is awesome but how do I get the Latitude and Longitude for that point?
curtvprice
Try the Add Geometry Attributes tool.
MichaelPickens
Ignore that I figured it out.  Add XY Coordinates was the answer.
curtvprice
Only if your features are in geographic. The other tool has more options, including calculating other geometric properties and projecting to another coordinate system before recording the geometry (so you can get decimal degrees when the feature class is in UTM meters for example).
