Any way to hide to/from popup when adding control points (georeferencing)?
6506
7
11-25-2020 11:07 AM
TylerBain
When I am adding control points while georeferencing there is a pop-up that follows my mouse around. This did not happen in ARCGIS desktop. The pop-up shows "From point (source)" or "To point (target)". I am having trouble selecting my points as these popups keep me from seeing what is on my map. It is not impossible, just annoying. Is there anyway to disable these pop-ups or at least make them semi-transparent?
Robert_LeClair
Esri Esteemed Contributor
Yes I believe so.  There are some keyboard shortcuts when georeferencing you can see on this page but basically hit the H keyboard key to switch the visibility of the control point ScreenTip off or on.
CMV_Erik
I don't have the answer, but I'd also like this ability. Even fading them after a few seconds would be better that persistently obscuring the layers
Robert_LeClair
CMV_Erik
H works for me - thanks!
Robert_LeClair
Great!  If you feel my response answers the question, would you be able to mark it as "Accept as Solution" to close this thread.  Thanks and have a great weekend!
TylerBain
"H" works to hide the popups, thanks Robert!
CMV_Erik
That doesn't seem to be an option for me, presumably because I'm not the originator of the thread
MattLashendock
This does not seem to be working for me.  I am working remotely.  Does this need to be done on the main computer's keyboard for some reason?
