Polygon creation tool
1412
11-11-2021 10:37 PM
DavidMrázek
Hello,
I would like to create a tool that finds a hole in a polygon and then loads it into a new layer as a new polygon. Has anyone had a similar project? Somehow I don't know how to start.
With the code written below, I can create a polygon in which the holes are located, but I don't know how to write them to create those holes.
I will be happy for any advice, idea or solution.
 protected override async void OnClick()
            var polylineFeatureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(lyr => lyr.ShapeType == esriGeometryType.esriGeometryPolyline);
            if (polylineFeatureLayer == null)
                return;
            await CreateFcWithAttributesAsync("Polygon", EnumFeatureClassType.POLYGON);
            var polygonFeatureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(lyr => lyr.ShapeType == esriGeometryType.esriGeometryPolygon);
            if (polygonFeatureLayer == null)
                return;
            await ConstructSamplePolygon(polygonFeatureLayer, polylineFeatureLayer);
        private Task<bool> ConstructSamplePolygon(FeatureLayer polygonLayer, FeatureLayer lineLayer)
            return QueuedTask.Run(() =>
                var polygonFeatureClass = polygonLayer.GetTable() as FeatureClass;
                var polygonDefinition = polygonFeatureClass.GetDefinition();
                var lineFeatureClass = lineLayer.GetTable() as FeatureClass;
                var lineCursor = lineFeatureClass.Search(null, false);
                var createOperation = new EditOperation()
                    Name = "Vytvořit polygon",
                    SelectNewFeatures = false
                while (lineCursor.MoveNext())
                    using (var lineFeature = lineCursor.Current as Feature)
                        var polylineGeometry = lineFeature.GetShape() as Polyline;
                        ReadOnlyPointCollection pts = polylineGeometry.Points;
                        // var polygonBuilder = PolygonBuilder.CreatePolygon(pts, polygonDefinition.GetSpatialReference());
                        List<MapPoint> lineMapPoints = new List<MapPoint>();
                        lineMapPoints.AddRange(pts);
                        var newPolygon =
                            PolygonBuilder.CreatePolygon(lineMapPoints, polygonDefinition.GetSpatialReference());
                        createOperation.Create(polygonLayer, newPolygon);
                return createOperation.ExecuteAsync();
thank you
David
DanPatterson
MVP Esteemed Contributor
A quick tour of creating tools with Python—ArcGIS Pro | Documentation
holes will make the shape multipart
Polygon—ArcGIS Pro | Documentation
Read geometries—ArcGIS Pro | Documentation
if you find holes, then the order of the points needs to be reversed
... sort of retired...
DavidMrázek
Thank you. Creating a polygon is no problem.
