pipe jump
2180
02-05-2020 11:54 AM
CaitlynMcNabb1
Is there an ArcGIS Pro tool equivalent to the Over/Under Pipe Jumps tool found on the ArcMap Water Utility Network editing toolbar?
  • Create Over Jumps for Selected Lines
    • Create a semicircle jump on selected line features over intersecting lines. You can set the jump distance in the configuration file.
  • Create Under Jumps for Selected Lines
    • Create a semicircle jump on selected line features under intersecting lines. You can set the jump distance in the conf
Thanks!
MartinPflanz
Hello, you may want to post this question in the Water Utilities  or https://community.esri.com/community/utility-network  community forum.
MikeMillerGIS
Esri Frequent Contributor
We have not ported this tool to ArcGIS Pro.  We have discussed the ability to use Attribute Rules, but that ability to modify the edited features geometry is not available yet.
GrahamWood-HWC
Hi @CaitlynMcNabb1  did you find a solution?
I'm looking at moving to UMN and trying find like for like for the existing tool-set
