PDF Attachments not showing
5633
9
03-24-2021 09:47 AM
MaryJoWatson
I am fairly new to ArcGIS Pro but have had success with attachments in arcmap. I setup my attachments, basically the same way as in arcmap, using the attachment tools. For the life of me, I cannot get the pdf attachment to show up in ArcGIS Pro. I click on the feature with the identify tool, but the attachment does not show. I have the pop-up configured to show the attachment! Am I missing something?
Robert_LeClair
Esri Esteemed Contributor
Mary - are you using this workflow listed here - please advise.
MaryJoWatson
Yes, I am using that workflow. It works for jpg but not pdf.
Robert_LeClair
Okay so we know attachments are working.  Silly question but do you have Adobe Reader installed on your computer?
MaryJoWatson
Yes, definitely. I can open the pdf that I want to use as an attachment. 😊
Robert_LeClair
Okay - sorry - had to ask!  🙂  So I enabled attachments on a Point Feature class, clicked the Edit tab, added a *.pdf to the selected point, saved my edit.  Then to test, selected the same point, went to the Edit Tab and clicked Attributes in the Selection Group.  This opened the Attribute Pane.  Clicked Attachments and saw my *.pdf.  Double clicked the *.pdf and it opened in Adobe Reader.  I'm using ArcGIS Pro. 2.7.2.
AnasAlkhrissat
whiteout edit tab, can the user see the pdf and open ?
RobertHolliday
Good Morning,
Did you ever figure this out?
ToddHelt
Hi, did you ever figure this out? I am experiencing same issue. Thanks in advance for any additional information.
Todd
StaceyMcDaniel
I came across this older post when I was questing the same thing in ArcGIS Pro for accessing attachments that weren't image files and found this today.  Hope it helps.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/configure-pop-ups.htm#:~:text=For%2....
