Parcel Fabric set up
1887
01-31-2022 01:23 PM
Zelong
I am trying to set up a parcel fabric for work as a test environment to see if we want to move to managing our parcel layer using this tool.  However trying to set it up just using the webpage is a bit much and I was wondering if anyone had any type of documentation how they set their up.
Particular issues I am having is trying to get the records type not to show numbers but split, merge etc.
Getting the COGO lines to show the distances
At this point I would also take any advice on what you need to do to your data before you get append it to the Fabric.
2 Solutions
Robert_LeClair
Esri Esteemed Contributor
@JackHorton - any ideas on best practices of setting up a parcel fabric?  And getting COGO lines to show the distances?
JackHorton
We cover all these things in this instructor-led course:
https://www.esri.com/training/catalog/5e5f25188cb2d966e64e3d5d/working-with-parcel-data-in-arcgis-pr...
Check out this Esri Community page with follow-on resources specific to the parcel fabric:
https://community.esri.com/docs/DOC-14868-working-with-parcel-data-in-arcgis-pro-class-resources
And you definitely want to join the Land Records Meetup to access the resource lists, recorded meetups, and live meetups:
http://www.meetup.com/Esri-Land-Records-Meet-Up
To get a textual record type, put a domain on the Record Type field:
https://pro.arcgis.com/en/pro-app/latest/help/data/parcel-editing/createparcelfabricrecords.htm
And to control line labeling, you can turn on labeling and optionally alter the arcade label expression:
https://pro.arcgis.com/en/pro-app/latest/help/data/parcel-editing/parcelfabricassociatedlayers.htm
Robert_LeClair
JackHorton
