Pairwise Dissolve GP tool creating gaps in output lines
2931
03-03-2022 06:15 AM
Labels (2)
LindsayRaabe_FPCWA
MVP Regular Contributor
I have a model that does a number of steps to a state wide road network. I've confirmed that all the way through the model, the generated data maintains integrity, but after running a final Pairwise Dissolve, gaps of roughly 0.7-0.9 metres wide are appearing randomly (not many) between the start/ends of some line features (image below). Any idea how I can prevent this?
Lindsay Raabe
GIS Officer
Forest Products Commission WA
DanPatterson
MVP Esteemed Contributor
Maintain curve segments environment setting is it set to preserve them?
Is Create multipart features set or unset?
and finally, can you confirm that the features actually met at their endpoints?
The dissolve won't make segments meet if they ever met in the first place, that would require
Extend Line (Editing)—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
LindsayRaabe_FPCWA
Maintain curve segments is not enabled.
No multiparts
Yes they met originally.
Lindsay Raabe
GIS Officer
DanPatterson
Your data to Tech Support for testing would be best.  If it can be replicated it would be a nasty bug for anyone needing to do network stuff.
LindsayRaabe_FPCWA
I think the Maintain Curve Segments setting has resolved the issue. The 2 breaks I've found previously are now connected. Will keep an eye out for others, but hopefully thats it! Thanks Dan.
Lindsay Raabe
GIS Officer
