Package Project referencing data on enterprise geodatabase
2269
6
01-03-2023 10:11 AM
MattCotterill
I'm trying to create a project package for someone in my organization who is using ArcPro 2.9. I'm using 3.0. I'm using the Package Project tool and the error I get is: "Layer's data source is inaccessible" The source for the data is our organizations enterprise geodatabase. Is that the problem? Is there a way around this?
Thanks!
Matt
MichaelVolz
Esteemed Contributor
Have you tried to copy the data to a file gdb and then try using the Package Project tool as a test?
MichaelVolz
MattCotterill
Thanks!
MichaelVolz
Will this other person be updating the data or is just a read-only business requirement?
MattCotterill
This is read-only work he needs to do.
Incidentally, we found a work-around so this isn't critical, but for some reason I was having trouble importing layers that were selections of datasets on the enterprise database. Any idea what that could be about?
MichaelVolz
Can you explain the problem with importing layers that were selections of datasets on the enterprise database in more detail?
MattCotterill
When I try to import or perform another geoprocessing function (like buffer) on a layer on the enterprise database, the tool just runs forever. When I try to cancel the geoprocessing function, the tool still runs forever until I force quit.
I can run tools on feature classes in my project geodatabase in this project.
I can run tools on feature classes in the enterprise database in other projects
I just updated from Pro 3.0.0 to 3.0.3
