Overwrite Web Tool (Geoprocessing Service) is not supported on federated ArcGIS Server with Portal
1994
11-09-2023 08:52 PM
SaurabhUpadhyaya
Hello Friends,
I have installed ArcGIS Pro 3.2, ArcGIS Server 11.1 and Portal.
I am trying to overwrite the published geoprocessing server(Web Tool) using ArcGIS Pro and it throws the error that "Overwriting is not supported to your Portal".
I am able to overwrite the feature/map service but facing the issue on overwriting web tool.
please share workaround to resolve this issue, it is impacting the delivery.
KatyLewis
Experiencing the same issue.  Same configuration.
jonathan_debrandt_infra
Hi, I have the same issue with the same configuration. Did anybody find a solution ?
RobertCao
Hi @SaurabhUpadhyaya
Are you trying to overwrite web tools to a non-hosting ArcGIS Server in this case?
Robert
