Output Workspace Does not Exist Hot Spot Analysis
1828
07-26-2024 09:48 AM
MadelineRatoza
Hi all,
I am running hotspot analysis using a spatial weight matrix. I can run the hotspot analysis using any other form of threshold distance (K nearest, fixed, etc), but when I try to run it using the spatial weight matrix file it gives me the error "Output workspace does not exist."
Has anyone seen this happen or know if I need to specify a specific workspace somehow differently when using a spatial weight matrix file?
Thank you!
DanPatterson
Generate Spatial Weights Matrix (Spatial Statistics)—ArcGIS Pro | Documentation
It would require a locally stored folder location.  specify the full file path and the *.swm extension
The full path for the output spatial weights matrix file (.swm).
... sort of retired...
MadelineRatoza
Thank you for the response!
I have created the matrix file .swm, but when I try to use that file to set the threshold distance for the Hot Spot analysis, it says there is no output workspace, but I am putting a full file path into the "Output feature class." The same one that I put in for any other hotspot analysis. Does there need to be something specific or different for the output feature class when using a .swm file to set the threshold distance?
DanPatterson
Load and save a spatial weights matrix file—ArcGIS Pro | Documentation
are you sure it has data in it?
Hot Spot Analysis (Getis-Ord Gi*) (Spatial Statistics)—ArcGIS Pro | Documentation
the output should be to a featureclass in a file geodatabase and the swm is used in the
Conceptualization of Spatial Relationships section of the tool.  If you navigated to the swm and you got that error, then it doesn't have anything in it or something else, like saved to a non-local folder,  or one-drive, etc
MadelineRatoza
This is helpful. I think I saved the .swm in a different folder that is not the working environment. When I go to pick the place for the .swm the working environment does not appear as an option for some reason. But I think this gets me closer to the answer!
